F7P head/ F7R bottom question
Reno 9
Hi all,
I started to put the F7P head on thd F7R bottom but I have a question:
what will be the head gasket from.
Is it will be from F7R as it has bigger bore or I can put the F7P with no problem.
also I finished my head work by porting and polish and remove 0.25 mm to increase the compression ratio to 10.6 : 1 approximate.
I hope that I can gain 10 hp from this setup
First: I think the actual head casting is the same between F7P and F7R in terms of combustion chamber size/shape. The bore size is only 0.7mm different anyway (so 0.35mm all round)... bugger all. Either will work.
Secondly: Skimming big chunks off the head retards the valve timing. So you now need some vernier pulleys and a proper setup to get it right if you want to see your power increase
OoOoPpPpS
So do you think that their will be side effects from increasing the compression ratio.
Because i will not be able to have those pulleys now.
