F7p Fastchips High boost ecu, injectors, map sensor and TB adaptor £180.00
Status
Not open for further replies.
James5
As per title these are no longer required as I have gone stand alone ecu, this is the High boost fastchips ecu so 14ps that runs @ 3bar fpr this is for an F7p conversion this is also a phase 1 ECU so demobilised, the injectors are 802 jobbies (renault 21t) and the map sensor is also matched to the map again this is an R21t jobbie. I will also throw in a spare TB adaptor for pipe run
I am after £180.00 collected or an extra £10.00 insured posted within the Uk. The setup runs fine as used my car just wanted the upgrade.
This is a good cheap way to get your turbo conversion up and running.
@DeanGT5 any good for you ?
Be no good for Dean as his spec differs from the ecu map file, you need to keep the setup to below
The spec the map requires is
8.0:1 compression ratio (wossners or skim to this),
Std f7p head and cam's,
GT28rs,
Adjustable FPR @ 3bar,
802 injectors
r21t map sensor,
these are the basics you need to stick to, I know you can run this ecu on a 200sx .64 turbo and it will be fine
Status
