Excessive Tire wear
  • Start date Start date
A
Anonymous
Hi,
Just made a new topic out of this.
I already mentioned it before, the cause of excessive tire wear on the front tires.
Also my experiments by changing the toe from -0.5 to +0.5
Well, let the image of a used front tire speak for itself.
As you can see the wear is much more even.
I can only refer to my car, which has a rear torsion bar, stiffer front bushings.
The straightline stability is a bit more nervous,
responce to steering a tad more agressive,
the point of oversteer when trailbraking comes a bit more agressive, but nothing alarming for a daily use, since you only perform this on the track.
I feels a bit more neutral in high speed corners. so less understeer feeling.
All in all I like it more, but I'm an old school rear engine driver.
