Engine rebuild parts needed - Atmo Gordini
Hannu
I had a bit of a knock on the new Atmo Gordini lump we have just fitted to my classic rally Gordini, and we pulled it apart and found number 1 piston had cracked rings and was lightly damaged.
We measure the pistons at 75.89 mm diameter and I have spare pistons and liners.
I need the following parts:
Cylinder head gasget set
Fresh set of valve springs - will GT Turbo ones fit?
76.0 mm piston ring set
Sump gasget
Big end bearing set
Has anyone got any of these parts lying around, or will I need to talk to Salv Sacco?
Cylinder head gasket set - mecaparts.com
Fresh set of valve springs - will GT Turbo ones fit? -no gt turbo ones are alot smaller. mecaparts.com sell a set of 8 race units.
76.0 mm piston ring set - mk2 r5 ones will fit as long as its a 1397cc engine - including gt turbo. (or goto mecaparts.com)
Sump gasget - mecaparts.com
Big end bearing set - FPS (ferraris piston services) sell these and the piston rings for the mk2 r5 - they will fit a 1397 cc mk1 r5. - or goto mecaparts!
:D
lucky you, he didn't want to help me out press bearings into a turbo 2 block. - although i do appreciate that supply parts is alot less labour intensive than working on these engines.....
i also heard he was retiring?
