Engine and chassis numbers?
philthy
Where are they on the mk1?
I have an idea they are below the rear covers but dont want to take them all off and then find they arent there.
Phil
For the MK2 you find the chassisnumber on the crossbeam just in front of the passengerseat (LHD) for you it would be driverseat.
You need to cut the carpet though, which is precut a bit.
Since the base is a normal clio for the MK1 it should be the same.
The thing in the door is just a sticker.
The enginenumber can be found next to the oilfilter, if I recall correctly......... I'm getting doubts, it might also be on the other side. :?
At least it's near the oilpan on the long side of the engine. :shock:
So, managed to wringle me out of this one :D
