Other ( non boosted Renault ) Electrical Issue Lights
Raj
1990 Renault 5 1.4 Auto.
When i turn on the lights my front side lights, Rear tail lights & number plate lights aren't illuminating and I'm unsure why!
Basically no rear lights are illuminating when the car is running
My Dipped/main beams, front & rear indicators, side repeaters, rear brake, reverse, are all working when "Activated".
Checked all fuses & bulbs to no avail. 🤔
I'll try another stalker to see if it works it, but is there anything else that i can look at? A relay etc?
Cross a 12v live to the cluster terminals and see if the bulbs light up, if they do then you're missing 12v feed and you can trace it back up the loom. If they don't light up there's an earth missing and you can trace that down the loom to earth.
