@stoneyV6,
I recon you got practical experience with it, so please provide me with info, so I can look into it.
(Standard Mk2 engine destroying a gearbox after hard launches).
CollinG I wouldn't be too worried, I've tested it quite a bit and it works ok, my box is still ok with the new clutchplate(currently 15000km).
And I also perform hard launches.
I recon some people just heard a few bits here and there. The main problem of the PK6 gearbox is the allowable torque. I asked the engineeringdept of Renault, and they came with 320Nm as absolute maximum.
The standard engine delivers on paper 300Nm, in practice it will be less. The weak part in the gearbox is the diff housing, (I think MikeT can confirm this) not the gears.
The hard launch is destructive if there is a lot of play in the gearingparts, which isn't the case with the PK6.
Even a hard launch doesn't produce more than max torque. It just comes on quickly.
Best thing to do before you perform a hard launch is to settle the box, meaning break slightly, release the clutch a little bit, so the box gets under a bit of tention, meaning forward moving play put to zero.
