so have had a set of front coilovers for my 5 sat there for a bit had a read up on them and now plan to fit them. Can you just fit a set to the front and any advise for setting them up on a 5 thanks
they are the gaz ones. fitted them today all wnet well. A test drive of the car felt so differnt almost as though the car now has power stering but pulls to the left a bit so when i get 5 mins ill take it for adjustment. will also need to have a bit of playing with the settings first as feels very hard over certain bumps in the road
Get a proper setup done - four wheel alignment, camber adjustment (with camber bolts) and so on. You'll only appreciate it after you have it all done and drive it.
