Clutch Pedal Change
Stuntedgrowth
Hey, my Vee has developed a very annoying squeak every time I push the clutch pedal down, the noise is coming from the pedal mechanism. Has anyone ever changed the pedal on there's? If so what's involved and what would cause it to start squeaking?
Thanks
Jamie
Its probably the plastic bush that is at the top of the pedal worn or dry, get on your hands and knees and spray it with wd40 before spending any time or money on it.
Had mine sprayed with WD 40 many times, and at one time some fine powder stuff (teflon I think they said). Still squeaks and creaks :)
Most items are inexpensive.... apart from Item 9 (£216.00 +vat) !!
James":7zfqrxvg said:
Had mine sprayed with WD 40 many times, Still squeaks and creaks :)
Are we talking about you or the pedal box james?
its bush no7 and pin no11 that needs greasing, obviously if you are taking it to bits fit new bushes (no 7), with a blob of grease.
Cheers this is exactly what I'm was looking for. I'll give it a quick spray, if that don't work I'll strip it down and grease it up.
:approve:
