Clio Clio 172 Sump
could try a wanted on cliosport.net
I'd expect it to be shared with any non turbo f4r that had a 5 speed box attached to it. laguna, espace and scenic
I'm not able to cross the genuine number to anything, yet some people offer a Febi sump which is meant for the Laguna and Kangoo 4X4 as being the same? So I've ordered a BGA sump for tomorrow to compare it and long as its right then I can order me a Febi for Friday.
When coming to refit the sump, Should I replace the gasket with a genuine reno type? Read a lot of people re-use the old gasket!! - Or 3rd party brands ok to use like Elring? And bolts too. Managed to remove them all without issue but worried about re-using them?
All sorted with no leaks which is good, used a little bit of Dirko where needed on the casing. Following the 172 workshop manual I did discover the sequence has 21 bolts where mine has 22! Guess they must referring to the F4R730 instead?
So for reference the Febi 27300 Sump does fit fine 😁
