Haz
On a side note to the van project, I've not experimented much with splicing looms on cars with canbus links and the likes so seeking advice, albeit probably to complex for me to understand!
I realise some components need to match, well most really. But when most differs and can't be used what are the options?
I figured the best way to start was to have similar year and spec.
2005 trafic full engine loom, aux loom, fuse box. Dash loom, fuse board and aux switches - ac, elec pack etc. Key, transponder, body module and ecu. It's a later loom than mine with a connector for the rear loom as the earlier ones were one peice so just that to add in.
2005 megane full engine loom, part aux loom, fuse board. Dash loom inc body module, key card and receiver, stop/start, instrument cluster and complete column.
Most mechanical items won't transfer so I'm hoping it's electrically possible or at least know for sure if it definitely won't work before putting many hours into it!
I've opened the looms up and at a glance the theory works with the traditional renault colour scheme keeping the basics simple.
Thoughts are - megane engine loom with all the aux bits removed. Lives, sw live, earths and relays adjusted and fitted to correct ones in the van fusbox. Minimal Megane dash loom comprising stop/start, transponder, card reader and card, instrument cluster and body module both with excess relevant loom removed.
All megane lives, sw live, earth and relays adjusted into the van dash loom and fuseboard. Steering lock and barrel removed, wiring adjusted to suit megane. Some wires transferred from van instrument cluster and to meg body module, mainly stalks related.
That, in theory, should allow it to run, not considering all the pedal switches, doors closed etc but that's the last of the problems.
The last component to be removed from the van loom is the body module. My assumption is that half the wiring will be disconnected when fitting the megane unit, thus the remaining should correspond with what is removed from the megane dash loom back to singular wires ie central locking, windows, ac. using the full van canbus just controlled by the meg unit.
As they're just switches I'm assuming they just trigger the body module and it should respond the same albeit throw some codes up?
Any input from experience?
Thanks
Thanks
