Can ayone help Fablio?
Jamesv6
He's asking me technical stuff!
INGLESE
hello I have a clio v6 1 I need a picture of the clio v6 2 I have to modify the suspension. you can send the photo of the clio v6 2 suspensions like the one I am sending you ?? I have to see if they are equal
[album]12336[/album]
ok thanks. I put in the clio v6 1 muzzle the front clio v6 2 find the front wheels back and I have to check if the attacks are the same suspension. Thanks
[album]12337[/album]
[album]12338[/album]
Hard to understand what is going off here, looks like he has put PH2 front end onto a PH1, It almost looks like the bottom wishbones are on the wrong sides!![album]12341[/album]Only photo I have and probably wont help!
Yes, this seems to happen when fitting a ph2 front to a ph1. Yarnis car used to be exactly the same. I doubt there is anything wrong with your car. Maybe you just need ph2 bottom arms, arb and struts to complete. Its probably how renault decided to lengthen the wheel base on the later cars for a slightly more stabble platform. It would also add a few degrees castor to I'd imagine.
As Brett said... This looks to be the same as Yanni's car. It'd certainly be interesting to find out what's different between the two models to cause the difference.
[album]12352[/album]
Google translated
james I have seen in the forum telling me to change the ball joint of my clio v6. the ball joint to change is the one pictured ??
