can a willy head go on 1.8 bottom end
pretty certain it cant as the oil and water holes dont line up or something.
No it does fit, Harvy you're thinking of the 172 head.
The williams head has larger valves and wilder cams. Go for it!
Will give you a little extra poke but you really need the bottom end for the extra F7R torque.
No problem at all, a lad round this way did it years ago, with a few other trick mods, his car was maad fast after 4000rpm! but just fit a 2ltr bottom end at the same time!
yes...
but at a great cost..as the inlet valves are well expensive.. :D
Will shift the power higher up and make the valver engine even more peakier than it already is.
done in conjuction with head work will increase torque across the range as well as an increase in bhp at the top end..
a worthy mod..
