I have a pair of the Brembo rear brake calipers which are fitted on phase 3 models for sale, both were working when taken off the car over a year ago.
£40 for the pair
Also have an offside rear abs sensor which is fitted in the phase 3 stub axle as removal would most likely destroy it.
£5
I have the other rear abs sensor but I had to grind the nearside stub axle to remove it from the beam so the stub axle is scrap, the sensor is fine but I can't be bothered with trying to remove it.
£2.50
Contact on here or via PM, Thanks
£40 for the pair
£5
£2.50
