Bosch Diesel Pump (Wanted)
Larry
Here's the latest, I have the F8Q 1.9D engine and it's got the Lucas pump, I want to replace this with a Bosch pump at the cheapest possible cost. Anybody know where I could get a second hand one, even a knackered one that I can get reconditioned? Also can just the pump be switched over or will I need to switch other parts over?
I've a couple here.you will need bosch injectors and the 4 pump to injector pipes aswell.other than that its straight forward. The same pulley is used on both pumps and There are 2 timing marks it,1 for the lucas,1 for bosch.
