Arj256
I have been looking through the search and there isnt much in the help for fault diagnosis.
Haynes is useful as usual.
I have changed the leaking rear brake bias valve for a replacement.
(for reference you can convert a clio one)
I bled up the brakes and the pumps working.
On the first few brakes all is fine.
Then the abs light comes on and stays on.
The brakes still work fine with the light on, but i fear this will fail me the mot.
If you switch off the car and start again its no longer on.
It also did it when moving.
Im going to be cleaning up the sensors tomorrow.
What components are there in the system and whats the usual suspects i should be looking at?
Also what is the proper way for bleeding bendix abs brakes?
Unfortunatly its not viable to be converting the brakes.
Thanks.
Thanks.
