Oldskoolbaby":jid2v1i0 said:Could be the PAS pump.
swilding":3dqka22h said:Thanks for the tips guys. I'll try and locate the noise a little better.
It certainly makes the noise with the AC off.
It is just one belt that does everything on the vee or are there a couple?
k1ano":g8lo3mr3 said:Dry auxilliary belts can cause a squeaking noise noticeable while idling - a light squirt of wd40 does the trick. if you want to validate this, spray a light mist of water on the belt and see if the noise stops, the water will evaporate so it's a good test if you are not comfortable spraying wd40 on them initially. This will isolate this is a potential cause.
