5 GT Turbo Battery Charger / Monitor
Ian M
What's the best battery charger that you recommend that monitors the battery, that i can just leave connected 24/7? Save buying a new battery every year
I use ctek on my cars that are used but sparingly.
If your not planning to drive for 3 months or longer best off dropping the negative terminal off if possible, and occasionally topping battery up on trickle.
Ive had a couple of batterys fail after continuous trickle charge over winter for whatever reason. One on blue meg fired up willingly after winter layup, then started up one more time and failed on 3rd attempt at the petrol station typically.
