Auto locking of doors
Fat_Board
Hi.
I have read thru the manual and it says that I can get the car to auto lock the doors.
I've tried to make it work, but somehow it won't auto lock.
Have anyone else experienced problems trying to set this up or is it just something I do wrong?
Not entirely sure what you mean.
When you drive away, the car should lock itself (if I remember correctly) when you get to about 10 mph. And the car will also auto lock itself if you unlock the doors but then not open any doors.
From memory, I think you have to press and hold the lock button in the console for a few seconds. Then the new mode will be activated and the doors will autolock when reaching about 10kmh. Same process to deactivate.
Is that what you mean?
Did you hear the beep?
Ignition on fully (not engine running)
The auto lock when you drive away function yes.
I have to say I can't remember if I heard the beep or not. But let me check it when I go see the car later this week.
I know I tried it before, and it didn't work. Thought I might as well just ask you guys now while it's in storage.
I will give you an update!
