G
Guest
I tried to drive my car today went fine for 500m or so.. then i struggled again to keep running..
got back to my yard and kept it running/idle for a while 1000-3000rpm for about 2minutes.. then it cut out
it smoked from both engine bay and exhaust pipe for several minutes after that and it smelled burnt.. and below exhaust i found oil on the ground!?
can this be caused by rocker cover leaking?
also some of the smoke is probably from ice/water remover i have int the gas tank..
oh and it was -3 degrees outside.. if it matters
