Hi all,
I am a MK1 Vee noob from HK.
Just got mine few weeks ago, I had put some fresh tires on and along with an alignment last week. Then I take a quick drive enjoying the new tires and then back home.
Anyways, I finally got the time to read the print out of the alignment, and it is saying that they have used a Clio III data.
The camber from left to right isnt really equal(front left -.54 deg and fr is -1.10 deg, rear left is -1.52 deg and rear right is -1.26 deg) for the current measurements.
Toes are both zero for front and both 0.18 deg for rear.
Left caster is 5.38 deg and 4.14 deg for right.
I called up and ask, they said, the camber/caster arent adjustable. So is this correct?
Also, using the wrong data from a Clio III to my Vee isnt a good measure for the alignment too right?
I will be glad if someone can host my alignment sheet if possible.
Quite a long post, please gimme some comments...then i will head back and ask for a realignment....
Dave
Dave
