Air Con question
s_o_n_y
Hi !
My AC dosent work. With Clip computer it said "4G Relay AC Compressor open sercuit CO.
I have found the pressure sensor and it is the one with 3pins. When i bridge the blue and orange one all the fan and the compressor kicks in. Sooo..i think i would change the sensor because its look like WW3 8)
But when i run Diagolys and all the info here its gonna be this switch http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
But all these had a round connector and mine is rectangular. And if i google some more i think this is the one.
http://www.ebay.com/sch/i.html?_sacat=0 ... 80&_sop=15
Why is it so ? Have Renault change partnr ? can you buy an adapter or anything ?
I have an PH1 Iceberg -02
Regards Robin
77 01 205 751 Sensor Pressure
£103.68
That's all I can find for the Phase 1 and Phase 2. No part change history shown.
Thank you James,.
That is the only one i can find and if you look at the pictures it is the wrong connector if you compare it to the one who is there :/
Try today to vent some gas but it was completly empty. So i should start in that direction. Leave it to an AC mechanic so he can find the leak.
