Szabotage":1mn2jgae said:
I looked into this issue too. Here are the part numbers if the issue is the ABS sensors, two are the same while the others are different lengths. Bosch is the OEM therefore the same product as Renault except it might be missing the diamond logo if at all. Although such sensors should be easy to replace, unfortunately it is common here for the sensor to be firmly stuck in the hub and pulling it leads to it breaking off yet leaving the sensor still in the hub. You should factor in time needed in removing each hub in order to drill out the sensor from the other side.
Front NS 7700411745 (Bosch 0265006384)
Front OS 7700411746 (Bosch 0265006385)
Rear NS 7700411745 (Bosch 0265006384)
Rear OS 7700411747 (Bosch 0265006383)
Really appreciate this, thank you!
I had already done some investigation work and indeed managed to find the Bosch 0265006384 for 16 quid off eBay, was very happy! It's my N/S/R that needs replacing. It seems to be the same part used for most of the Mk2 Clios.
Will have to pay the garage to do the work but I think they wanted about £90 for the actual part, so finding it myself should have definitely helped.
Yes, they said the sensor will be stuck in the hub and they will have to break it out. What do you think is a fair amount of time to be charged to do it? Half an hour? One hour?
