briera2
Ok so nearly there on the energy engine in the R11 but a few questions about wiring and the carb.
First, could someone tell me what the third pipe connector is on the back of the carb? I've looked up the Haynes and a workshop manual but they don't show this?
Next is my alternator. I'm using the alternator from the C1J and for some reason it has two capacitors to ground. Does anyone know why?
Lastly and my biggest problem is the ignition. The E6J ignition module has three wires which are all striped green. One is yellow which (correct me if I'm wrong) should be 12V, black is ground and white is tach. On the R11 harness I have purple which I measured 0.6V and I presume is tach, brown which I measured 0V and must be ground and murky white which is measured at 12V. I get no spark when I have a plug connected straight to the main cable. I'm tired so I could be mixing the white and brown wires. I'll check tomorrow.
Also, I'm an idiot and forgot (and can't figure out) what order the plugs go into the distributor. No.1 is marked though.
