1997 Megane Headlight removal & fit
mega
My friend has a megan 1.6 1997 , he had a little bump on the front end and he has to replace his front headlights.
Can anybody here give me any quick tutorial on how to remove and re-fit them please.
Thanks for any help
Unbolt front bumper
You need torx to remove plastic near headlight
torx to remove blinker ( one on the top and than pull it out)
3 bolts to remove headlight
The plastic grille at the headlight is t30 screws and its clippe dunder the headlight a tug frees it.
The blinker torx is t20
the bolts are 10mm for the headlight. the 10mm fromt eh bottom, the bumper doesn;t have to come right off but its a lot easier
Whenever i've refit megand headlights i break the rear tabs off the bottom brack so it just slidesin, its fine once tightened up
the shitty bottom clips are normally broke anyway.
Beside you just need to pull the bumper forward and you cxan get in with a ratchet spanner or 1/4 ratchet.
Stepehn kept smashign his so his headlights were changed every coupel of months.
Nightmare tryign to find any with the bottom mount intact.
