19 16V phase 2 door trim clips
cookie17
Hi guys,
I'm sure it has been asked before but i am looking to see if anybody has or knows where to get trim clips for my 19. I have been into Renault and the clips come part of the trim which is approx 200 euro for all 6 pieces. I used bumper restorer on the trims and they came up lovely. Id prefer not to glue them on so any help would be great. I can post a picture of the broken clips if needed.
Thanks
Brian
Go to your local wreckers and get a few, twist and pull, easy.
or,
I had a couple that just wouldn't clip in so i removed the clip from the body and filled the trim bit with "araldite" or similar around a 5mm bolt sticking out and when set then poked the bolt through and put a nut on it from the inside of the panel. pulled in nice and tight and no panel or trim damage.
cheers.
