Wanted 13 toothed speedo drive pinion for NG5 gearbox
I have plenty of NG5 'boxes. Will check for you but I am very busy at the moment. What do you mean by replacement bung? Which bung, where?
Hi thanks for the reply, ive had a chance to have a closer look at the "bung" the green nylon thingy that the speedo drive pinon sits in is mangled on the side where ive levered it out but i can turn it around and reuse. but the o ring on the outside has perished, the inside one has a bit of rubber that was floating around inside, so i would ideally like to change them both.
do you have part numbers, or a parts list
