Current Reg – Y23 RDL / Previous Reg GY61 OGK - 133.5K and rising as in daily use, has minimal finance left on the car (2 Months), and if it sells, I will clear the finance on the car with a NON-refundable deposit before the car goes, and will provide proof of this.
Will Do Turbo Renault a Price of £6750
Also have a full set of Steeve alloys i can throw in the sale, had 2 x Blasted so bare metal, just to others will need done (No Tyres)
MOT Due Jan 26 (Will Be putting a Fresh 12 Month Ticket on the Car)
Megane 250 Lux (Cup Pack – Red Calipers & Cup Shock)
6 Speed Manual
Cruise Control / Speed Limiter
Shift Light/Beep
Vis Pack (Bi – Directional Xenons & Washers)
Leather Recaros (Slight wear - would class as good condition)
Dual Climate Control
RS Monitor
USB / AUX input
Bluetooth Connectivity (Handsfree Phone)
RS Mats
Space Saver Spare Wheel & Tools
18” Cup Alloys
4 x Matching Uni Royal Rainsport Tyres
Age Related Marks around the car
I’m 4th Keeper
Modifications
Uprated Braided Brake Lines
Mapped from EFi by Chris, both megane’s have been done there now, with a safe reliable map (308.6 @ Fly & 341.8 Torques @ Fly)
Uprated Braided Clutch Line (May 23)
H&R Lower Springs
Hubcentric Spacers
AIRTEC Intercooler
Sports CAT
Panel Filter / Silicon Inlet Pipe / Boost Hose
Upgraded Injector Bolts/Nuts
Maxton Boot Spoiler
Front Mud Flaps
Maintenance
Part Service – 2015 / 2016 / 2017 / 2019 / 2020 (Inc Timing Belt) 2021 / 2022 / 2023 / 2024 / 2025 (Receipts from 2023 onwards when I acquired the car, Service book pre this)
TPMS Valve (Feb 23)
Drop Links & Track Rod Ends (March 23)
Uprated Gearbox Mount Bolt (May 23)
Front Brembo Pads (Dec 23)
Rebuilt Front Caliper (New Pistons & Seals) March 24
Rear Brake Hose – N/S & OSR (March 24)
Rear Brembo Pads (April 24)
Drive Shaft Seal Replaced & Gearbox Oil (May 24)
Rear Caliper (June 24)
Pollen Filter (Aug 24)
Rear Discs (Inc Bearings) & Pads (July 25)
Oil & Oil filter, Spark Plug (Sept 25)
Timing Belt Kit / Dephaser / Water Pump / Aux Belt Kit / 2 x Core Plugs / Coolant (23/10/25) RENTEC in Edinburgh done the work
If the car sells then happy days, i have a hankering for something different, but i’m in no rush to sell.
