Renault 21 Turbo 2WD braking system
When I press the pedal handbrake light flashes ones for about 0.5 seconds.
Is the braking pump dies? Or what it means?
Thank you.
Check your brake fluid level in the reservoir. The handbrake light indicates “Handbrake on” or “Brake fluid level low” if it comes on on its own without the ABS warning light.
Fluid level is Ok.
One of my ABS sender damaged, so ABS warning light is always on…
