R11 Turbo Carb Q
Hi, I have a Renault 11 Phase 2 Turbo in the workshop. My mechanic is having trouble setting up the carb and asks if anyone knows what the float height and main jet size should be. He is also not sure if it has the correct one fitted, it’s a Solex 32BIS and the part number is 24M60203.
Any help gratefully received.
Not possible to adjust float height on 32dis.
Main jet 120.
should be a 32DIS carb not a BIS
Good spot there Adey!
Need more info than just being unable to set up the carb..
Main jet should be 120 , most were swapped out to a 135 , for people wanting more boost..
Float is not adjustable and not a cause of a running fault, ask him for more info or some pictures of what he is having trouble with..
Is it running rich, lean , not starting , revving to high etc…
Wow loads of replies to a newbie, thanks everyone.
I will check if he said B or D, could be my cloth ears over the phone.
The car is not modified so should be on standard boost but a recon carb was fitted by others a couple of years ago.
It is running far too rich and fouling up the plugs, you can start it with no choke. I’ll ask him if there are any more detailed symptoms and update here if so.
Absolutely fine to do so.
Has it been choke deleted? Can we measure any of the jets and the carb throat? I seem to recall group A carbs had choke delete and enlarged parts.
Just caught up with the mechanic.
It’s definitely a BIS, can this be set up to run well on a Turbo model or should I be looking to change it?
Annoying as it was sent off for reconditioning through a marque specialist a few years back.
To answer other replies there isn’t a choke delete and running rich is the only problem found so far.
yeah thats a no, only the DIS was designed for boost pressure. You need to try and get a turbo carb for it
As above, if thats a BIS fitted, get that binned.
Any pics of it?
Would also be interested in pics, but yes you need a 32DIS as the others have said!
OK will be looking for one. Is it the same as fitted to the 5GTT? Quick search in the usual places just now has not turned up anything so I might need to be patient.
Pics of the carb that’s on it now, or the car itself? It’s offsite but happy to upload when it comes back.
Yes, fitted to all C1J turbo engines.
If you need a carb i can possibly get you one built.
as said above, this carb needs to be removed … The BIS is only good for non boosted engines, while its rich on idle it will go massively weak on boost and a great way to destroy an engine… Hopefully your mechanic has only been trying to get it idle , not a road test where he gives it a boot full or rolling road..
See a known specialist for carb work or rebuilds, Like Sparkie above …not much he hasn’t come across when rebuilding used or worn carbs… any carb from 9 Turbo,11 Turbo or 5Gtt Turbo will fit but there can be subtle differences between jetting depending on whats its been used for…even if someone tells you its been refurbed , please get it looked over by someone before fitting it .
more pics the better , on or off the car, even the car itself please for us car nutters, we love the old skool stuff. but pleaaaaaaaaase tell your mechanic not to run it any more on that carb and too give it a good oil and filter change before the new carb goes on… running rich when cold will have got petrol into the oil.
