I have found a company that can make PU Bushes for me.
I have designed bushes for the renault 21 turbo quadra.
For now it is possible to order bushes for:
The rear wishbone (quadra)
The front wishbone (only cast iron)
I need a least 5 orders to make this a succes.
If this turns out oke then I can also make bushes for:
The rear droplink
The front sheet metal
The rear subframe beam
Other
The prices are:
Rear quadra wishbone 23,75 per bush 47,50 per vehicle set. 2sets required.
Front wishbone (cast iron) 23,75 per bush 47,50 per vehicle set. 2sets required
Al bushes come with stainless inserts. It is possible to choose between different hardnesses: Shore 95A, 80A and 70A and they will all have there own color.
Is there any interresed for this? I need at least 5 people for this to start up.
@Rob21tq You are more than welcome to start a list mate on this post. Just keep adding people as they request the parts.
If you are going to co ordinate this I would strongly recommend that you take a deposit or better still full payment for the items so people cannot back out and you end up with lots of kits
Regards the hardness, I presume its the same rating as wheels for skates, I use a few between 74a and 82a. I wouldn’t suggest using the 70a as probably not much different to std, and 90a will be rock hard, more like plastic.
Just food for thought.
Why do we have to be difficult!
Why were they supplied with different sizes? &, short of measuring them, is there any way to tell based on age or phase of the car?
