Hi,
I need rear coilovers for a ph1 21t, will take 1 if available, thanks
Hi,
Gaz (UK suspension company) do 2wd (proper) coilovers, not sure on lead times.
Mespieces do OE replacement, make sure you replace suspension in pairs, its dangerous not to.
https://www.mespiecesauto.com/en/produit/renault-21-turbo-rear-shock-absorber/
Cheers Dave, dont want to spend too much right now as its stuck in the shop, spring is cracked.
It will never see the road at this rateā¦
Thanks for the tip
