My GW R26
My 08 Glacier White R26
So i thought it was about time to start a project thread of my GW R26
Unfortunately the only photo i currently have of the 26 is on the back of a AA Van
Sorry i know threads with pictures are alot more interesting, just getting a starting point so i can actually keep on top of it.
Engine Spec
T20 Turbo
3" Turbo Back Exhaust
ARP Crankshaft Main Cap Stud Kit
ARP Cylinder Head Stud Kit
King Racing Big End Bearing
King Racing Main Bearings
PEC Forged H Beam Rods
PEC Racing Forged Piston
Seimens Dekka 630 Injectors
1.3mm Head Gasket
TTV Solid Mass Flywheel
Genuine R26.r Clutch
Custome Pace Front Mount Intercooler ( 4" Core )
Forge Dump Valve
Forge Adjustable Actuator
Replacement Oil Spay Jets
Gates Powergrip Timing Belt Kit
Auxiliary Belt and Tensioner Kit
Short shifter
KTR Racing Engine Mounts/Gearbox/Torque Mount
There Will Be Bits I Haved Missed
Interior / Exterior
Sabelt Fixed Seats
Sabelt 6 Point Harnesses - Removed
Sabelt Side Mounts
KTR Subframes ( customized to actually fit )
Custom Rear Bar
Bc Racing Track Spec Coilovers With Solid Top Mounts
R26.r Rear Spoiler
Standard Wheels Powdercoated In .R Red
New Brakes All Round
New Door And Tailgate Looms
Fog Light Blanks
Xenon Conversion
Again there will be bits that i have missed off
Originally i set out in search of getting more power, ( i can only thank mr bond for this ) so i set about getting a forged engine, luckily/unluckily a friend of a friend was selling one ’ complete’, not going to go into too much detail about that. Anyway the engine was bought and after bits and bobs was swapped from my engine to the forged unit it was in. The next job was to get the mapping transferred over from their ECU to my ECU, unknown to me the immobilization codes could just be swapped alot easier and alot cheaper. Anyway everything was transferred over and run on the dyno making 298bhp & 290Lbs, although under WOT its clipping the upper boost limit, this still needs to be sorted.
As the car stands at the moment, it needs the mapping tweaking and the interior putting back together.
Its a sound base to work off ! Going to be a quick car @Lee Maddern
Cheers andy, and thankyou for all the help advice over the past year :smiley:
Also looking to get some Decals for the 26, original checker fags if you or anybody knows where to find some ?
More than welcome. :slight_smile:
@Big Steve - Raider knows the man that can for the decals.
Wojciech Zylski is the guy you need in Poland. Find him on Facebook :slight_smile:
Wojciech Żylski
Are these print on vinyl like the originals ? also i dont have facebook :smiley: i hate it!, could someone price me a set up, front/rear bumper, side decals and roof decal ?
