Hello everyone i have a renault fluence i successfully swapped a full megane 3 rs 265 cup in it but i left my original wiring loom for the dashboard, now i want to install Bic wiring and Rlink1 system all parts are ready , my car has Bose system with small screen like the one from Rsmonitor v1 , any one have simple instructions on how to install everything?
Absolutely no idea!
Sorry ![]()
Been there, done that (starting vom Carminat live 2.0)
I wouldn’t consider it a simple job, even though the result is worth the pain (imho).
Full R-Link setup requires the following hardware:
R-Link screen (basically 2 types available, different type of touchscreen technology)
BIC, as multimedia master
radio, possibly not with Megane layout, but with central command knob, since there is no place for Megane “joystick” in Fluence
USB/SD/AUX hub
satellite behind steering wheel
antenna(s) GPS, FM and (optionally) DAB, all-in-one versions exist
TCU units became completely obsolete.
Depending on donor cars more or less configuration work should or even has to be done for proper function.
Wirings can be partly adjusted, but quite a few are even missing at all, of course.
I thought mine had RLink but it was just the gloss black surround. I have seen a place in Australia did custom harnesses along with the hardware to convert. But as Jay said, weigh up the pros and cons of getting it done but I will be keeping an eye on this if you get it down as I would like to see it done
