Guys…would it be possible to swap the ND0 gearbox out from the megane 225 and fit a PK4 gearbox?
What would required to be changed along with the gearbox?
Big job? Worth it?
I have a PK4 box from a meg 250 cup that has a limited slip diff and I’ve been trying to wrap my head around getting it in a meg2 225..
Tia…
If its going in to a meg 225/r26, you will need 175 dci driveshafts, 175dci gearbox mount, and 175 dci shifter or equivalent, and meg 250 clutch/dmf.
Not worth the hassle, id stick with ndo. Works fine, pk aint great, if its for lsd upgrade go for quaife or gripper diff in the ndo.
Sounds like a bit of work…
You would be better off selling it and putting an lsd in the ndo.
