Anyone no where the fuel pump relay or fuse is?? Need to do a compression test but dont want any fuel going in and flood it!!
Also does the engine need to be warm or cold to do a compression test. I was told cold from a reliable source but the compression test kit i just brought says from warm.
run the car up to temp, remove the king lead and if you really don’t want a bit of fuel in the cylinders just unplug the injectors. It only takes 4-5 revolutions to test each cylinder,so it wont take long.
