Exhaust rubber hangers..
I need new exhaust hangers for the 19. They’re similar to these: RENAULT MEGANE 1.4i EXHAUST RUBBER MOUNT HANGER x 3 (R13)
Any tips on how to find good quality ones (preferably cheap!)? I mounted the stainless exhaust with new ones a few months ago and they’re already starting to crack.. :frowning:
The part number is 7700785798 and the OEM is either Bosal or Walker so if you get either of those then you’ve probably got the best ones you find.
worth noting that the mk1 megane equivalent 7700849461 is slightly different - i think it has some kind of plastic insert which may not necessarily solve the problem you’ve got.
Basically the stainless exhaust is much heavier than the OE one and the OE hangers were never designed for that weight. You might have to get creative. Do you have the 2 at the centre of the car in place?
Yes, I have the 2 at the center.. It’s a piper exhaust with a much smaller centre box than the original. Also I’ve put on a metallic sports cat, should also be lighter so in total I think they might be about the same weight..
I used the hangers that were supplied with the exhaust but they seem to have been made of an inferior compound..
Ordered some Bosal’s now, hopefully they’ll last more the 3-4 months… :slight_smile:
I have been using Walker mounts for the last couple of years and never had a issue. I do however always keep a couple of spare ones in the boot.
I had a piper backbox and was quite disappointed with the weight. Much heavier than I expected it to be. Also I could never get it to mate properly with the middle section. Always leaked a bit.
I have the piper catback and found it to be really easy to adjust, both for clearance and fit.
I’ve also have had a stainless bolt on cat made: (Yes, the O2-sensor hole is on the wrong end, but it doesn’t matter since the sensor sits in the downpipe.)
