Clutch fitment help
I’m mating an megane 225 f4rt to a pk6 gearbox form a f4rt Laguna
Does anyone know if I’ll be able to on use the megane clutch ?
I think you’ll get the best answer if you just take the clutch + flywheel from your Megane and try if it fits to your PK6 (if you have it already). As I wrote in the rsmegane forum they have different part numbers (lag vs meg clutch, flywheel, clutch slave cylinder), so probably not a straight fit. But just my guess.
Id expect the Laguna clutch to fit, i’d not expect the Meg clutch to fit (but hope that it would work).
If it were mine i’d ask around the forums for a used/worn clutch & slave from a Meg to throw in a dummy build to see if it’ll play ball. Someone will have something you can get for nowt.
