Current spec of the car to the best of my knowledge, as i had to put it together as part of a massive jigsaw puzzle.
Engine/Fuel system
Megane 250 block, custom J.E. forged pistons (around 8.3:1 with 197 head iirc, id need Steve to confirm).
Catcams conrods, balanced crank and rotating assembly. Block prepared by AMAC, including hone and decked to suit.
Arp hardware, head studs etc.
Ported 197 head done by AMAC in Northallerton, with larger Supertech valves, double valve springs (catcams?) and titanium retainers.
197 inlet cam, 182 exhaust cam using 197 vvt setup. Timing currently set to stock.
Custom Nortech inlet plenum with internal trumpets, centre fed Bosch motorsport DBW throttle. Inlet/head is dowelled to locate perfectly on the head.
Custom Nortech exhaust manifold to suit twin scroll turbo with 2x 38mm tial external wastegates for each pair of runners, venting back into the downpipe. Egt sensors per cylinder. Ceratec coated.
Garrett gtx3071 gen1 .82 twin scroll turbine housing. K&N air filter.
Intercooler/pipework is custom by Nortech, intercooler is bar and plate garrett core rated to 600hp iirc.
Direnza radiator, Mtc silicone hoses and 12" Comex high flow cfm fan. All shrouding fitted correctly to force air through rad and intercooler.
3" custom turbo back exhaust with 2x sliencers, 2.5" slash cut tips for discreet look. Possibly made by Btm/yozza would need to confirm.
Ecumaster black standalone ecu, on my own custom engine bay wiring harness. 980cc bosch motorsport long pintle injectors (flowmatched), running full sequential injection and 197 vvt on pwm so full scope of 40deg inlet advance available.
Audi R8 coilpacks and Ngk Bkr8eix plugs gapped to 0.7mm.
Egt per cylinder using Ecumaster egt to can module. Oil pressure/temp, fuel pressure/temp, wideband 02, dbw throttle and various other essential sensors all feeding back to the ecu. Mac valve plumbed in for boost control, 4x separate boost settings on potentiometer fitted in car via Ecumaster can switchboard for expansion.
Ecumaster edl1 data logger fitted in glovebox logging all ecu parameters onto sd card, and bluetooth, which displays all gauges via canbus on an android tablet or phone.
All connected up to the oem clio 250kb baudrate canbus syetem so oem dash works nice. No warning lights present, dash works as oem, stock engine ecu fully removed.
1.5ltr swirl pot fitted in boot with Bosch 044 fuel pump, sytec fuel filter, turbosmart fpr 1200 fuel pressure regulator.
-6an ptfe lines fitted front to back as return system, oem pump used for lift pump for swirl pot.
Battery relocated in boot using 50mm2 wiring from memory, maxi fuse fitted in boot, bulkhead connector and distribution block fitted in engine bay. Optima Redtop battery fitted in billet alloy tray.
Transmission/running gear
Megane r26 NDO box with gripper diff, oem megane 6 speed shifter and cables.
Clio v6 pedal box and reservior for meg hydraulic clutch.
Custom motorsport driveshafts for meg NDO to clio fit. (poss made by Dave Mac?) Made to flex under extreme conditions to take some strain off the transmission.
Ttv megane r26 smf flywheel, Helix 6 paddle clutch and pressure plate.
Vibratechnics engine mounts and custom dogbone torque mount made by Nortech.
Bilstein B14 coilovers.
Clio 2 epas conversion/column on looped 182 rack.
Whiteline rear arb.
Front subframe seam welded and powdercoated.
Track control arms fitted with PMS strengthening plates and powdercoated. Both tca’s and arb polybushed with powerflex bushes.
Renaultsport steel sump guard powdercoated black.
Northloopcup roll correction kit. Front geo currently set at -2.5deg camber and 10 mins of toe out overall.
Wilwood jamsport 4 pot brake kit up front with Reyland 2 piece discs and Ferodo DS1:11 front pads, Motul RBF 600 fluid.
Larger diameter piston brake master cylinder for sharper pedal feel, and custom braided pipework to re route the bulkhead brake pipes away from the turbo whilst retaining abs, and pipework to suit hydraulic clutch.
Speedline 2118 wheels in anthracite, et43, Toyo R888R tyres.
Interior
Recaro CS leather/alcantara seats up front on Jon foz subframes. Mint unmarked 182 rear split seats.
Snappy retrimmed steering wheel.
Clio V6 pedals.
Alpine stereo, focal components and crossovers, small alpine amp discreetly mounted behind dash.
Bodywork
Stock trophy as intended, wind deflectors.
Current power output
Currently mapped by EfiParts to 349hp/300ft/lb at 14psi due to issue with fuelling system (fuel line resonance) but should go high 400s once sorted. Low boost with wastegate pressure of 8psi gives around 270hp.
A couple of awesome pics took over the weekend many thanks for them.
