Im selling a complete, B18FT Engine removed from a running Volvo 480. The engine has 114k, i may even have the clocks from the car to prove this, although ill have to check.
For sale is:
Complete engine with all ancillaries i.e turbo, manifolds, injectors and loom and both ECUs (Fuel and ignition ECUs).
The gearbox with both driveshafts.
I also have the cylinder head and manifolds off the GTX block that can go on the B18FT to run it on carbs, rather than the standard injection, which i may throw in for the right price.
Also got a GTX 1.7 camshaft that can go straight in the B18FT and is a more aggressive cam.
The wiring loom was chopped in half when i got the engine from the person who removed it. I repaired this and can be seen in the thread i started a while back when i was going to do the conversion.
Times are hard, i really wanted to keep hold of the engine but i just cant afford to spend on it, and have it sat their. Id rather it go to someone in the Turborenault community as your all top lads. Get back to me on here if anyone is interested, although its advertised elsewhere but ill let it go cheaper on here.
Im not necessarily leaving the community, i just need the pennies. Cheers for reading. Josh.
