As per title,
With my new 5 pot rs3 lump and 7 speed DSG going into the rwd vag 5 I no longer have a real need for the current 1.8 20vt / 5 speed setup
This is the same combo I used on my original vag powered 5 as the 6 speed is too big without lots of cutting
Engine is bam (tt 225 and strongest oem bottom end) with agu head (need to double check) and k03s turbo.
DG
Would go well in a Clio… If only I had somebody to do the donkey work…
It would
The 6 speed may even fit in the Clio but the 5 def would
DG
You going to fit it for me?
As its you Dave, you can use my hoist
It is currently mated to the oem subframe and ‘may’ fit into the front with the brackets James made up
If going into a Clio use the oem top mounts of the engine / box.
I could consider fitting and doing the fabrication but I have such little free time still atm bit hesitant to offer…
DG
