Hi All,
I think this is related to my previous post. Basically went to take the car out for a spin today and when I turned the key this time the speedo went nuts the green gear stick light flashed on the dash, the doors locked and the seatbelt bleeper started. The car wouldn't start though.
I called the recovery and they put a booster on the battery and it started but the speedo was going up in parallel with the rev counter, the seatbelt warning buzzer came on and the doors locked. The car wasn't running right and kept slowing slightly but the engine management light didn't come on.
The recovery guy cleaned the earth and the battery terminals and each time the car would only start with the booster and each time the speedo and other gremlins happened.
He tested the battery and the state of health was on the change % amount and the state of charge was 75% which is fine.
For some reason the speedo is moving and this is controlling the door locking and the seatbelt bleeper as somehow the brain is thinking the car is moving?!!
I took the car for a drive as he wanted to see if it would cut out but literally only 200m and the engine management light came on. Pulled it back on the drive and turned it off. It then wouldn't start even with the battery booster. Speedo and other electrical issues were still happening.
Eventually it started and I put it back in the garage.
I know I need to get it to Renault but at the moment it won't start so has anyone got any ideas what the heck is going on?
Is this just a battery issue?
Cheers.
David.
[smilie=thanks.gif]
Cheers.
David.
[smilie=thanks.gif]
