will this fit my 255? are they fronts??
  • Start date Start date
I'm no expert but i'm pretty sure the front discs on a Vee (255) are 330mm, so i would say these are too small and wont fit.... [smilie=doubt.gif]
More "Stuff"
FRONT BRAKES (in mm)
Slave cylinder diameter 41.3 - 38.1
Disc diameter 330
Disc thickness 30
Minimum disc thickness 28
Thickness of pads (including
support)
17.75
Minimum pad thickness (including
support)
9
Maximum brake disc run-out 0.5
REAR BRAKES (in mm)
Slave cylinder diameter 57
Disc diameter 300
Disc diameter 24
Minimum disc thickness 22
support)
18
support)
10
