Brilliant info guys 215/40 going on the car on Monday. Amazingly its the first change of the front tyres since new ie 22000 miles. I know the vee is rear wheel drive so dont expect as much wear off the fronts but thats not bad going in my opinion.
Yep ... fronts do last a long time and even then only scrub out on the inside edges thanks to the standard toed out geometry. I've had 18k out of each of my two sets.
Make sure that you spec the 97 load rating on the rear whatever you get. Less load rating gives very very nervous arse end as i found out once when i didn't check properly what the tyre knob had fitted.
www.elitedirect.com are doing the fronts for £82 or near as damn it delivered at the moment - BARGAIN
Those backs must be mahoosive! Do they fit on alright? My pilot sports are about dead on teh back so will get some FK452's to match my fronts, wouldnt mind something a bit wider though!
