wheel spacers
Louis
Does anyone know where i can get some good quality wheel spacers for the phase 1 17 inch wheels front & rear.. & what mm size should i go for ? for a nice fit to bring the wheels level with the arches & how much longer mm wheel bolts do i need ?......can anyone help....
I'm not sure about phase 1 sizes but I'm sure if you measure from the outside edge of the tyre to where you want the wheel to sit that would give you your sizes give or take :approve:
Larkspeed stock H&R wheel spacers in 5mm, 10mm &15mm and are top quality LINK
You'll need to make sure you order the 5 stud pattern for clio Mk2.
As above, work out how much you want to space the wheels out. Once you know what spacer thickness your going for then add the thickness of spacer to the standard wheel bolts and order longer bolts, IIRC the standards are 28mm. So if you decide on 10mm spacers you'll need longer bolts of 38mm ( but you'll probably only find them 40mm )
More spacer info HERE
