What size tyres do turbines have?
G
Guest
What size tyres do turbines have? I might be buying a set with 3 new tyres on, want to price up a new tyre before i buy them, anyone know wot size tyre i'd need?
Thanks :wink:
I run 195/45/15 on mine which is handy if your going to lower your RT alot, prevents the rears from rubbing (usually) :lol:
was thinking of lowing it either 35 or 55mm. the tyres that the turbines i might be getting will have the 185/55/15's on. How low should i go with these do u reckon?
will be fine -35 (should be ok -55 as the rt is higher than the valver)
i actullay got 195/45/15 front and 205/45/15 back on my turbines.. works just fine,, however the rear wheels are a little oversize.. won't change until i burn them or something :lol:
I had to down from 55 to 45 when mine was lowered -55 on the back due to it rubbing out. Still couldnt take passengers either :cry:
i think mine is standard and i can take 1 passengar.. 2 and i have to drive really easy..
I am just thinking of the adjustment to the speedo needed if running a different overall diameter with slicker tyres...is tehre much difference between say 55 and 50?
as in 195/50 and 185/55?
If it is there is a fraction of an inch. Does fuck all to your speedo.
Biggest modifying myth ever that is.
My physics isn't great, only having a c or something in gcse many years ago, however, I think if we fitted a 30" wheel to a clio and it said 30mph on the speedo, it would be travelling a lot faster than a car with a standard setup. Would that be right?
no, slower due to rolling radius.
but in real terms the highest you could realy go would be 17/18's on low profile tyres which will make a difference but not in the same way people make out.
Plus if you are spending that sort of money just get a GPS speedo, job done. :D
