Has anyone got Ph2 hubs for a Renault 5 gt turbo for sale? In need of a pair so I can fit my koni's on my campus.
Also does anyone know if these will definitely fit on a campus?
Are the Konis Ph2 fitment? If they are you will need Ph2 Top Mounts too if you don't already have them. If they are Ph1 fitment, I think you can use your Campus Top Mounts?.... Someone else will no doubt confirm this.
Phase 2 fitment. The bottoms and tops are the only difference as far as I'm aware. I'd be getting phase 2 top mounts but I thought the holes that bolt on to the bottom of the shock are different too.
The bottom of the shock/strut IS different, but not the hub. Basically you must match by phase. Ph2 Strut with Ph2 Top Mount and Ph1 Strut with Ph1 Top Mount.
I've tried phase 1 coilovers with campus top mounts and didn't fit at bottom, also tried my phase 2 koni's and they don't fit at bottom either. I know you have to match Ph1 and Ph2 and not to mix them up. Someone had mentioned that theft was an inbetween like a phase 1.5 and that's what is confusing me. Nothing fits and its getting a bit frustrating.
Thanks Andy. It's a weird setup on my car as the holes on the hub are out of line like Ph2 and the top mounts are in line like Ph1. It's a nightmare to try get a decent suspension setup.
That's the thing, the tyres aren't wearing atall, it's perfect. It's baffled most people including myself, tracking, wheel balance and camber are all fine. I'd change everything but I don't want to spend a fortune on all the bits. If I could get a decent pair of Ph2 top mounts and hubs then it should all go together pretty straight forward.
