Interesting video. Big difference, i'd go for the second set all day long.
IMO:
Drilled discs are weak and crack from the drill holes. Avoid.
Grooved discs with lots of grooves are weak and warp really easy especially if the grooves reach the edge of the disc. Avoid.
Drilled and grooved, obviously, avoid.
Grooved like the ones you have are better, stick with those or normal flat faces.
If you're turning calipers different colours you might need to think about upgrades. Bigger discs, bigger pads, more pistons in the caliper. The faster your car gets the more braking you need from higher speeds and you start to stretch the OE specced kit. You've done a lot of work to it so maybe bear that in mind.
Also remember the extreme stresses on these components. If you think you're going to get away with hundred quid discs not cracking with regular track use think again! The heat cycling is extreme and the constant expansion and contraction will take its toll. I put good quality flat discs on the 172 (standard brakes) with EBC red stuff and im halfway through the pads and there is heat fractures all around the disc surface and a MASSIVE crack that I can now feel through the pedal in the front offside. I'm pretty brutal on brakes though
I need a proper upgrade cos it scoffs brakes like a fat bird scoffs chips and the new suspension and tyres have just exposed the brakes as the weak link. Not in performance, but in "I can't take this shit any more".
I had the same problem with the 21, cracking, warping etc. I went from a single piston caliper to a 4-pot, 285mm disc to 330mm and red stuff to yellow stuff pads. Fluid to ATE Super Blue. That setup has done 4000 miles around UK and Europe, track time at Blyton, Silverstone, 4 laps of the Nordschliefe, 3 sessions on Nurburgring F1 circuit, and 2 30min sessions at Spa Francorchamps (Brutal on brakes!) and only now am I seeing some small heat fractures on the discs. I havent had a set of brakes last that long in all the time I've owned it - going on twenty years. No fade. No scary moments (not caused by brakes anyway).
Whats my point? I'm not sure, aside from you should probably get another credit card
