Urgent! Cooler for MK1
pwrdesign
Hi!
I need a new cooler, and I've got trackdays planned in 2 weeks :(
Does anyone know what kind of cooler that's used in the Clio V6 MK1?
Brand, model number?
Regards Patrik
Patrik, what do you mean by cooler ?
Are you referring to the front radiator, oil cooler etcc ?
Its too broken to rapair, and renault sweden needs 3-4 weeks to get one to sweden... :(
Isn't there any other Renault thats using the same kind of Radiator?
Patrik,
I am no expert with this but providing you can use a radiator with the correct capacity then any radiator should be suitable as the thermostat and temperature sensor will determine how to control flow of the coolant to the front of the car. Of course fixings for the fan cowlings, the location of the inlet and outlet hoses and the size of the radiator will be important to ensure that it can be installed.
I would guess it is more likely that a clio radiator will fit rather than a random vehicle.
Here is a site I found with pictures and dimensions of radiators which may help ...
Mk1 Clio Radiators
MK2 Clio Radiators
Renault Radiators
You're the best martin! Thanks!
But I have to look at the meashurements...
If I guess, my radiator is closer to 60cm wide...
