Updating Car Unique infomation?
matt.v10
Tried updating this in my profile. Was going to add:
TTV Lightweight Flywheel, Pipercross Induction, Recaro Sportster CS, OMP Corsica 95mm dished steering wheel, OMP Spacer 70mm, 10mm Rear wheel spacers, Michelin Super Sports, Braided Brake lines, Original AP Racing Pads, Refurbished front AP Calipers Painted Black/ White AP decals, Upgraded copper bushings in gear linkage, Factory refurbished Original Koni Dampers, New interior plastics, New gear knob, New front luggage Compartment, New orginal steering wheel (in storage), New wheels from Dieppe group buy, New front Fog lights, Full cambelt and ancillaries by SG Motorsport 04/2015.
Message returns that I do not have the authority to edit this info...
Just thought I would mention it.
Thanks
Matt
:approve:
Matt, seems like your Vee has been through a thorough overhaul ;)
How do you find the TTV flywheel?
PS: I too just tried to modify #002's details, and got the message.....
When it was 'editable' I believe there was a character limit, so you may need to refine your description...
Just tried to use the 'Found a V6' tab, but once I'd filled in the details and submitted.. the note on the screen read "Sending of a report is NOT YET IMPLEMENTED"
Was the information I sent saved elsewhere, or lost?
Cheers, Shaun
Would it be an idea to remove the "Found a v6" tab until its operational once again? Or perhaps a warning before all info is applied? ;)
